Don: I understand, with that aside for now, what if the 110.16 rule in the NEC was applied where I would field mark the equipment as indicated.
...... field marked to warn qualified persons of potential electric arc flash hazards.
Some of that marking is very simple, and is available from manufacturers of equipment with a warning like:
WARNING!
Potential Arc Flash Hazard
Appropriate PPE and Tools Required
when working on this equipment.We know that the FPN's are not enforceable.
Also, what if 70E Chapter 1 was added to the NEC instead as a new article, or at least in an annex item?
Would that give some useful information to the industry?
I have been told that the cost for PPE for each person, can vary from a few hundred to over a thousand dollars.
What have you implemented in your facility?
