Another point here in Britain is that the double-contact bayonet-cap bulb is by far the most common type of fitting, at least in domestic applications. Polarity on such bulbholders is completely irrelevant, although on portable lamps which incorporate a switch there's still the problem of reversed wiring at the plug leaving the switch in the neutral.
