Kenbo, Welcome to ECN.
Leds: Their lifespan is based upon 'running' hours at their nominal operating voltage and current. ( around 100,000 hrs )
In case of Red Led's 1.7 volts dc 20 mA
Yellow and Green Led's 2.2 volts dc 20 mA
Blue and White Led's 3.6 volts dc 20 mA
to give some examples. ( Data sheets are usually available from the LED suppliers.
and quoted values above may vary a little )
An LED is a light emitting diode. In forward biased mode at the U.nom and I.nom, the LED emits light. Is an LED subjected to a higher current The LED will overheat and fail eventually or loose a lot of it's brightness before failing altogether.
An LED does not like to be reversed biased and a reverse voltage of about 5 to 6 volts dc can be fatal for the LED.
An LED can be pulse driven at a lot higher current provided the ON OFF ratio is adequate for a cool down period of the LED.
e.g. 100mA for 50mSec and OFF for 500 mSec.
Under normal running conditions LED's don't get warm at all.
The newer Luxeon LED's like the 1, 3 and 5 Watt types are a whole different cattle of fish. These are supplied with data sheets and have to be adhered too otherwise they will fail earlier than expected and they are expensive to destroy by means of a wrongly applied voltage and the like.
An LED is not affected by the amount it's switched ON or OFF.
Effectively at 50 or 60 Hz ac the Led will pulse at the frequency. It's important that an antiparrallel diode is fitted across the LED to protect it from reversed applied voltage.
In traffic lights LED's are usually fitted in strings of 5 or 6 in series with a suitable dropper resistor to avoid loosing all the LED's in case one LED failed.
Led on photo is Red LED on 230 Volts 50 Hz
2 x 33k resistor and 1N4007 diode in series.
1N914 or eq. in antiparrallel.
yields about 3 mA through LED for a long lifespan.
[Linked Image from static.flickr.com]
edited for typo's and photo insert. Raymond
[This message has been edited by RODALCO (edited 04-26-2006).]
[This message has been edited by RODALCO (edited 04-27-2006).]
