The Japanese FM radio band stretches from 76 to 92. The rest is used for TV audio for channels 1, 2 and 3.
Below the Japanese FM band is the Eastern European FM band....which goes down to like 66-something Megahertz.
Here is a Japanese FM radio from WA2ISE:
Here is a Eastern European FM radio from WA2ISE also:
In most NTSC countries (with the exception of Japan), the range below 88 FM is used for TV channels 2, 3, 4 and 5. So on the Japanese radio you will find TV channel 5 and TV channel 2 or 3 audio on the E.E. set.
