bonsoir paul uk : yes i am oringally from france and now i am in usa and i do speak both langaunges .
as far for usa phase rotation it is genrally set for clockwise rotaion but not alway be marked the correct way and it is abc set up but few have cba set up as long it have a warning sign but myself i use the phase tester to verify the roataion because from time to time it can go backwards with out warning and if all the cable are black or unmarked then iuse the tester to make sure due some macherney cant go backwards at all merci marc
