David,
Many thanks for taking the time and trouble to track down the information.
I've never heard the term "Building Warrant" before. As I understand the system, in England & Wales we have planning permission (or planning consent). It would always be needed for a new building, major extension, and so on, but not for many minor extensions and changes, unless located in a conservation area or something like that. Quite separate, however, are the Building Regulations which apparently apply to all works, whether planning permission is needed or not. But as far as they go, they seem to make no mention of electrical systems whatsoever. So basically, residential wiring isn't regulated by anything or anybody.
If I've got my facts straight, there are really only two legal issues which might apply. First, if a contract specifies compliance with BS7671 (which most will), then obviously any works not in compliance would be breach of that contract. Second, if somebody were hurt due to dangerous wiring, there could be a lawsuit against the installer on the grounds that if he weren't competent to carry out a safe installation then he shouldn't have done it at all.
It sounds as though your Electrical Completion Certificate just puts on record who was actually responsible for the wiring so that if there are any problems down the line it's easier to trace who to hold responsible. Here, I see dozens of dangerous situations, but by the time I find them, in most cases nobody has the slightest idea who did the work.
Belgian,
Here in Belgium the Electricity supplier company doesn't give you electricity before that you have a third organisation which come and do the testing and then seal the main Differential (gfi)
Is your main GFI owned by the power company, or by the house owner? In England only equipment up to and including the meter itself is PoCo property. The main GFI (RCD) is not sealed at all.
