I've finally got a digital camera working here, so here are a few quick photos from around the neighborhood to start you off.
First, a couple of shots of typical local MV power lines in a rural area:
Here's a typical 3-phase pole-mounted xfmr, again as found in rural areas to feed a small group of houses. The primary side is 11kV delta:
And here's the secondary side, 240/415V Wye. I'm afraid this one didn't come out too well, but you can just make out the three fuse pull-outs on the pole:
{Edit: Image replaced with a better one!}
[Continued next message]
[This message has been edited by pauluk (edited 07-07-2002).]
