Your problem is the resolution of the monitor does not match the computer and the monitor for some reason cannot adjust itself. (a common problem I run into) Plug an older CRT monitor into your computer. Reset the resolution to the lowest setting, to do this, right click on the desktop, go to properties, settings, save you changes. Then plug in your new monitor, and reajust your resolution how you want it. Robert
