I can't honestly tell you how long it took me to do it. The last .gcd save date is in May '03. I was designing the proposed system while I was drawing it. If I'm going to do a drawing, I want it to be something that can really be built. I'm sure that it must've taken more time than our high priced consultant's drawings that depicted devices that can only exist on paper. By sweating the details I knew that I could swing open the inner panel without clipping the Photohelics, and close the front door without pushing jog buttons. I like to think that I could send you this drawing as a dxf, with a few cut sheets, and that you could find the actual part numbers. (except for the contact blocks) At least I have the components created for the next time I need to use them.
Joe
[This message has been edited by JoeTestingEngr (edited 07-09-2006).]
