Here are some photos from my recent trip to Hawaii. The first is from the USS Arizona. These were the biggest pin and sleeve connectors I’ve ever seen. They were about the size of my leg. Very impressive little boat…..
The next is from the resort I stayed at. Note the wire exiting the box through a ‘custom hole’ at the bottom. This wire snaked through the rocks to a round plastic box with a fixture. The whole outdoor lighting scheme at this place seemed like an afterthought.
The last is also from the resort. Note the sign is plugged in via cord. The line down the middle is a seam in the concrete. PVC conduit enters the box from above. Notice the little white cap…..every plastic box at this place had these white caps on the top. They looked more like water PVC water pipe caps.
