Tangled up in all that almighty mess, notice the push-fit grey pvc mains-water pipes, [pic 2], in a jolly assortment of 15mm and 22mm OD, and all practically unsupported, [the token 'pipe supports' are electrical clips!]. These pipes will be on at least 50psi water pressure. Some water pipe is insulated with a foam jacket and some not (?), and one portion of insulation jacket is stripped off (pic 1), [probably got in the way of his needles as he was knitting the cuffs!!!]. My experience of these push-fit pvc plumbing fittings is they break without warning even when well supported, usually right under a bath at midnight. So, a plumbing nightmare as well, and even more fun and frolics to follow!
Why did the pub landlord allow the mess to get this far? It must have been patently obvious to even the most feeble minded that the so called 'contractor' was a berk long before things got this bad.
