HV,
Different states vary a bit, but I'm willing to bet it's not much.
A journeyman gives direction to an apprentice, but a journeyman, by state law (at least in VA) cannot pull permits, an must take direction from a master. If it is a master licensed electrician involved in your scenario, they are quite culpable for the work they directed.
I always tell my students that getting your masters license is not necessarily a good thing
![[Linked Image]](https://www.electrical-contractor.net/ubb/biggrin.gif)
FYI, I've been asked to testify as an expert witness probably about a dozen time (once to save my own Butt) and will tell you this: If you are a master, and get into a squabble with an engineer (PE or not makes no diff) the court will throw out the testimony of the PE in favor of your practical experience, given that you have credible argument. It's worth considering carefully. Remember the guy in Conn. that was convicted of manslaughter for improperly installing a bad heater.
I look forward to hearing from our barrister on this one though.
