Joe,
I always enjoy your code violations column in here and in EC&M and since I've seen a few myself I thought I'd send one in for you to add to your collection.
I only wish I had a better picture for you!
Whenever you research an industrial facility for a system re-design you generally come across some questionable installations.
During one several years back I stumbled across this unique one.
Although difficult to count, this 600 V - 100 A breaker had approximately fourteen (14) separate conductors ranging from #14 to #2 AWG under each load side lug.
Each conductor ran a considerable distance feeding separate devices.
Do you suppose this would be considered a code violation?
This situation has since been corrected as part of the system re-design.
Dennis T. Croughwell
Mgr - Central Maintenance & Facilities Services
