There is no real standard for control circuits here, it depends on the equipment, and you should be provided the shop drawings that indicate coil voltage for the starters. It could be anywhere from 24 volts to 600(575) volts.
As for the wire colour, natural grey for neutral and green with yellow stripe are mentioned in the code book, but the most common colours from the suppliers will be white for neutral and solid green for ground wires.
