0 members (), 236 guests, and 10 robots.
Previous Gallery
Next Gallery
#191751 01/11/10 03:23 AM
2 Images
wa2ise Offline OP
Crawfoot extension cord
Another oldie. This extension cord would probably work well in Australia.
6 Comments
My guess is that it uses green/white/black conductors in the cable. What way round are the black and white conductors...and are they the same at both ends?
Also, are the pins labelled as to their connections?
wa2ise Offline OP
I added a picture of the plug without its cardboard insert, and the hot pin (connected to the black (hot) wire) looks to be marked as reddish brass color. Which is consistent with a diagram at http://www.accesscomms.com.au/images/reference/Mains%20Plugs%20&%20Sockets/POWPLUG.GIF at http://www.accesscomms.com.au/reference/powerplug.htm
Same thing at the other end.
So, the live/neutral polarity is the same. Regardless of that, I'd have no hesitation using that extension lead here.
If these fittings were still commonly available in the U.S. I'd bring some in to make an interesting change to the same 2 or 3 local brands of plug and socket. And we have the same size wall box (even the screw threads are the same)which means the wall outlets could also be used.
wa2ise Offline OP
These occasionally show up on the American eBay. The hard part is finding the specific auction using keywords non-electricians would use to describe these plugs and outlets. "old", "vintage", "bakelite" or even "crawfoot". Be aware that there is a 30amp version that looks quite similar, but are actually a little larger.
I noticed that modern Australian outlets have switches to turn the hot wire on or off. I would guess that this is a code requirement. If you did use a vintage American crawfoot outlet, you might be able to meet this code by having an American light switch (some are rated at 277VAC) right next to it in the same box to switch the outlet's hot wire.
wa2ise Offline OP
While surfing eBay.au (was looking for interesting tube radios) found this auction:
American looking Aussie outlet ebay auction "The electrical mechanisms in DECO "BAKELITE" range are manufactured in Australia by Clipsal and carry full approvals." Wonder if that approval is by a recognized authority you use in Australia. confused
I have two 30a amp extension cords (25 and 50 feet) with the 10-30 plug and receptacle plus a short 14-30p to 10-30r adapter cable for using my big pressure cleaner and welder at other people's houses from their dryer plug.
