532
32
... Here's a picture of the "puller" my mechanic's Grandfather made for us to help with last weeks arduous 150 ft,250kcmil,underground service pull,...and you guys might just laugh at it,but the joke's on you,...the little thing worked like a charm,..no expensive wire pullers for me... He welded pieces of versa-strut together,along with a pulley wheel he found in his automotive parts milk-crate in his garage.. Don't you guys go and steal his million dollar idea,now..(patents pending) (edited to put picture on ECN's server) [This message has been edited by electure (edited 11-13-2005).]
Thats a nice rig your grandfather made, but I don't think the pole will fit into my truck, so I am going to keep my super tugger for a while.
... ...I don't think the pole will fit into my truck, ... Ahhhh,but that's where you're wrong,and the genius of this device begins... the pole telescopes down from a whopping 30 feet to a neat and totally toteable 3 foot section... easily stowed in your pipe-rack for future use.. Russ ... and it wasn't MY Grand-dad,it was my worker's Grand-dad whose brainchild this was... ...It will be appearing in a "Ronco" infomercial soon,.. Ron Popeil>>> <(known for his invention of a can of SPRAY PAINT to combat male pattern baldness,as well as the "Veg-A-Matic") will tout it as the "Ronco Pull-A-Matic"....I can't wait! (this item is not available in stores).. [This message has been edited by Attic Rat (edited 11-13-2005).]
Attic Rat, Is that puller attached to the pole with coach-screws?. Putting screws and other such things into the side of a pole can compromise the weather proofing of the pole and in time cause it to prematurely rot out, if the holes are not sealed.
... Yes,Mike,..they are 3/8"dia.X 2"lag screws,..but I got the OK from the PoCo inspector before I did it..the pole is coated in creosote,and the holes will be dressed upon completion.. Russ
So that's where all those "Leaning Poles of Pisa" came from!! I think you'll find the creosote goes a tiny bit deeper than a coating;- the vacuum-pressure system used means it practically goes all the way thro' the pole section. As to a patent, you've posted this in the public domain now Russ, so its all ours! ECN strikes again!! Who the heck is Ron? Alan
Very impressive Russ. 150' of 250 mcm sounds like a lot of weight. What size pipe? and who was the horse on the business end of the pull? (I have this picture in my head of a couple of guys dangling from the rope...it's not budging because the wire is over 400 lbs.)
Dave
Mike Putting screws and other such things into the side of a pole can compromise the weather proofing of the pole and in time cause it to prematurely rot out, if the holes are not sealed. That must be a down under thing as Alan pointed out the creosote goes deep if not all the way. Besides our poles are likely to be brought down by a car or truck long before they rot. Bob
AR I have just one suggestion (OK I have more but I will keep quiet ) If you use this rig again put a second pulley at the base of the pole so that you are not placing to much 'side' loading of the pole as you pull. It is also easer for people to pull up on a rope pitched down then pulling down on a rope pitched up. Loss of traction becomes an issue, this applies to pick ups and vans as well as people.
(OK I have more but I will keep quiet ) ... I'm still waiting for the other shoe to drop........... what's your other suggestions? C'mon,Bob, now you've got me curious.. Russ
