546
27
Posts: 3,682 Likes: 3
Administrator Member
Gee, Dave, I'm sure glad it's not my office that looks like that
It's kinda interesting to see three generations of services here - past, present, and future.
The SqD fusible panel doesn't look too bad, except for being obsolete. Are you leaving the can in place as a J-box to the new panel, or is a complete rewiring in order?
[This message has been edited by mamills (edited 09-17-2004).]
All of the old will be removed on this one, Mike. The original fusebox is one of the best I've ever seen, except that the snap-in of the 240 volt fuseholders are weak. The small sub-panel is wired in from lugs on the main at 100 amps, another very nice feature.
Dave
Those 1/2-1" eccentrics on the bottom of the meter allwys want to break out to a 3/4 when your putting the 1/2 ground pipe in. I gave up and just use reducing washers from the start.
Would that water spigot stay there?
I'll mention that to the homeowner, chi spark. It may stay though, there's a hose reel, so they'll only be conecting and disconnecting the hose a couple times a year.
Dave
Uh....did all of this actually pass inspection, or did they even get one? Yikes!
"Live the dream, you only get one chance."
This did pass inspection, but it looked better than the first three pictures when I finished.
It was a timely upgrade. The lower main lug on the fusebox spun rather than unscrewing (fourth picture).
The fifth picture shows a little creativity in metal-work by a previous electrician, and the sixth picture was my lesson that you can't bash a plastic part in the middle with lineman pliers to remove the knock-outs.
Dave
Shinnston, WV USA
