#118458 09/17/04 01:17 PM
Another Day at the Office
- Dave55
Gee, Dave,
I'm sure glad it's not my office that looks like that [Linked Image] [Linked Image]
It's kinda interesting to see three generations of services here - past, present, and future.
The SqD fusible panel doesn't look too bad, except for being obsolete. Are you leaving the can in place as a J-box to the new panel, or is a complete rewiring in order?
[This message has been edited by mamills (edited 09-17-2004).]
All of the old will be removed on this one, Mike. The original fusebox is one of the best I've ever seen, except that the snap-in of the 240 volt fuseholders are weak. The small sub-panel is wired in from lugs on the main at 100 amps, another very nice feature.
Dave
Those 1/2-1" eccentrics on the bottom of the meter allwys want to break out to a 3/4 when your putting the 1/2 ground pipe in. I gave up and just use reducing washers from the start.
Would that water spigot stay there?
I'll mention that to the homeowner, chi spark. It may stay though, there's a hose reel, so they'll only be conecting and disconnecting the hose a couple times a year.
Dave
Uh....did all of this actually pass inspection, or did they even get one? Yikes!
"Live the dream, you only get one chance."
more from Dave55:
This did pass inspection, but it looked better than the first three pictures when I finished.
It was a timely upgrade. The lower main lug on the fusebox spun rather than unscrewing (fourth picture).
The fifth picture shows a little creativity in metal-work by a previous electrician, and the sixth picture was my lesson that you can't bash a plastic part in the middle with lineman pliers to remove the knock-outs.
Dave
