Greg Really I do understand what you are saying, it is a simple task and could be performed by any one that has hands.
That said you are not familiar with the inspection process here in MA.
There very few inspectors I have met in MA that will do a 'drive by' inspection. They get out and check the work....really.
Example; I recently took a rough inspection in an office remodel, the inspector looked in all approx. 400 outlet and switch boxes, sometimes with a flashlight to make sure my grounds where made up.
I also did a large job that had dozens of Cad welds to rebar, the inspector was out each day to look at them before the cement was poured. I actually tried to get him to sign off on the rest after the first couple of days...no way, he wanted to see each one.
99% of the time I must be there when he gets there, it would be a bad move to send a helper to take the inspection. If the inspector does not know the person has a license he will ask to see it.
We also have a separate State department of licensing that can stop by any job at any time and ask to see everyones license or apprentice card. (An apprentice must register with the state and carry their card)
What you are suggesting will never happen here in MA.
It's OK though as during the 2002 code cycle we had an amendment that basically said I do not need to connect to the footing if it is already poured when I get the job.
I do not know if that will remain in 2005.
Bob
