You mention that he will quote greenfield, (flexible metal conduit) watch out that he doesn't just pull SO cord through the greenfield. I've seen it done. It is a Code violation. Alan--
Alan- Your such a skeptic. Must come with the job of being an inspector Unfortunately I agree with you. I've had a "contractor" install plugs and plates for the finish on a pipe job and no wire in the pipe. Yes sometime the job of an inspector is justified.
