0 members (), 1,328 guests, and 10 robots.
#96910 01/10/06 09:57 PM
NJ, has adopted the NEC "As Ammended" just like any other state does. So I guess that Nj is just using the NEC as a guide line for their own code. Shockme, I hear rumors that the 2005 will be adopted real soon, but you know how that goes. We will just have to wait and see. As an AHJ, I am asked that question all the time,, but I don't know the answer. My elec. contractors Assoc. sometimes get more info before I do.
Workgear for Electricians
#96911 01/11/06 07:44 AM
Mike
we know the ground wire is the real main component in the working of an afci breaker because it has a built in gfci.
A GFCI or AFCI does not require a grounding conductor to operate.
If there is no ground wire there will be no arcing to it. A line to line arc would (should) still be detectable.
