0 members (), 261 guests, and 38 robots.
#9688 05/11/02 07:07 PM
Cindy,
The galvanic destruction of the mc cable would be a very slow process. If there is enough moisture in the interior of the wall space to support the galvanic action, I would expect that the wall itself (drywall) would fail long before the MC cable. It also could be a source of "sick building" phenomena because of the mold that would grow. There is a high school in St. Charles, IL that has been closed for more than a year do to mold problems.
(http://www.isbe.state.il.us/construction/Headlines%20April%202001.htm#_2.__MOLD)
They don't know how to fix it and may end up tearing the building down. So it is my opinion that if the wall area is that wet there would be much more serious problems then the damage to the jacket of the MC cable.
#9689 05/11/02 11:06 PM
Vaguely related…
Wasn't there a big tiff over dissimilar metals in raceways several Code cycles ago that led to 346-3a? "Aluminum fittings and enclosures shall be permitted to be used with steel rigid metal conduit, and steel fittings and enclosures shall be permitted to be used with aluminum rigid metal conduit."
noderaser
noderaser
Portland, Oregon, United States
Trumpy 5
552,807 Are you busy
427,421 Re: Forum
397,917 Need opinion
