0 members (), 812 guests, and 33 robots.
#92758 04/06/05 12:17 AM
Can somebody help me find a code citation that prohibits the dimming of receptacles in a dwelling? I seem to recall a thread from a short time back, but I can't find it.
#92759 04/06/05 12:32 AM
I can't help you with the code referance. I do have a solution.
Lutron has special Rec and cord caps for dimming use. The cord cap is slightly different but will work in any outlet. The dimming rec has a smaller size terminal and a rejection bump. No other cord cap fit it.
Call for prices first. List price seems high. They claim to be the only maker of such a thing.
#92760 04/06/05 08:13 AM
#92761 04/06/05 08:19 AM
Oh, the code reference:
404.14(E)
#92762 04/06/05 08:05 PM
Active one I just inspected a home with this Lutron dimming receptacle device installed. While it is a Listed device it doesn't satisfy the requirement for receptacles in the wall space. I gave the contractor an option of changing to a "standard" receptacle or adding a "standard" receptacle. He added a standard receptacle.
George Little
#92763 04/06/05 08:18 PM
OK, so it's not that I can't dim a receptacle, just that the dimmer must be rated or listed for that purpose.
What I actually want to do is dim cabinet lights that have a X-FMR mounted above a cabinet, so the recep isn't a convenience recep in the first place. The lutron recep sounds like a good idea anyway.
#92764 04/06/05 09:15 PM
Gregtayler,
Lutron makes 2 versions. A split version with 1 regular & 1 special dimmer rec. The other one both sides of the duplex are made for the special dimmer plug.
If they had the split version (with one side normal) wouldn't that satisfy the wall spacing.
For a fixed cabinet a wip fed transformer might be cheaper and easier.
#92765 04/06/05 11:02 PM
An interesting thing about that Lutron recept is that, while it has a ground contact, it doesn't appear that there exist any plugs with a ground pin that will actually mate with the recept--their plugs are two-pronged. Unless I missed one somewhere.
#92766 04/07/05 05:16 AM
jes Offline
There have been issues applying dimmers to general use receptacles since you cannot predict what will be plugged into it later on. Some appliances react very poorly to receiving a solid state dimmer output!! Likewise, the system you are trying to connect MUST be rated for connection to a dimmer and may specify the correct device(s) to use. Certain dimmers are NOT rated to operate magnetic devices such as transformers. Be careful!!
#92767 04/07/05 06:04 AM
Z
Gregtaylor,- If you can hard wire this transformer,OK, If not just make the recep a single one.
noderaser
noderaser
Portland, Oregon, United States
Trumpy 5
davey 1
551,480 Are you busy
426,003 Re: Forum
396,790 Need opinion
