0 members (), 101 guests, and 109 robots.
good answer KNOB-AND-TUBE i will twist if i have 3 or more conductors but never tape there should be no reason for it if no copper is showing under skirt of wire nut
Workgear for Electricians
A careful reading of the manufacturers' instructions will reveal that you are supposed to twist the nuts tight enough that the wires are tristed together inside the nut. Simply having the wire nut hold wires next to each other is an incomplete installation.
That said, pre-twisting is very wise for neutrals in multi-wire circuits. I also often pretwist all wires evceot for the pigtail leading to a device; this facilitates later maintenance work, as the pigtail is then wrapped on the outside of the 'twist'.
What I want to know is how many more times are we going to discuss this?
Yep this one is right up there with "How many times do you torque aluminum connections?"
Some of these questions can not be answered without controversy.
George Little
Had an apprentice who was left handed and always twisted wires the wrong way. Thus untwisting them when installing wirenut
What is a "wire nut"?
Someone hand me my soldering iron and friction tape....
Speedy Petey
I like to twist the wirenuts before i stick the wires in.
You need rubber tape to go with that friction tape.
Speedy,
A soldering iron is way too slow, you need a "dip pot".
Don
I perfer to solder the connection, install a wire nut, install rubber tape, followed by varnished cambric, then plastic tape (3M #33) then friction tape followed by another layer of plastic tape. This is for splicing #14 AWG residential NM cable. For something more demanding I let the experts handle it.
George Little
George,
I thought that you installed the varnished cambric first and then the rubber. That makes it much easier to open the splice back up when you have to work on it.
Don
