0 members (), 923 guests, and 10 robots.
#89323 09/13/04 08:50 AM
hi,
there are NO requirements to GROUND a FITTING that has splices..you may be required to ground a box but a fitting is NOT a box..
mustang
Workgear for Electricians
#89324 09/14/04 06:57 PM
So, Mustang...the question is...IS the volume marked by the manufacturer on this LB???
Dave
#89325 09/14/04 07:09 PM
Dave,
The L.B. is marked with the volume. However, I used a 6X6X6 CARLON PVC J-BOX instead of the fitting for this particular job. There was no real need to use the L.B. since it was so easy to use a J-box..this is good to know for those times when there is really no other option. The J.B. was about $10.00 and it gave me plenty of room to work.
I also used aluminum instead of copper for my transition from Romex to Outside wiring method..XLPE in PVC conduit. The same stuff I use for UG services.
Thanks for the reply.
-regards
Mustang
[This message has been edited by mustangelectric (edited 09-14-2004).]
