0 members (), 274 guests, and 11 robots.
Page 4 of 12 1 2 3 4 5 6 11 12
#87966 05/12/04 08:30 PM
Fred: You get a green tag from this inspector. [Linked Image]
Ryan Jackson,
Salt Lake City
Workgear for Electricians
#87967 05/12/04 09:53 PM
Yes, I will be there in SLC, haven't missed one since 1981!
[Linked Image from joetedesco.com]
#87968 05/12/04 10:10 PM
I am an AHJ and I would not fail someone for using the remaining screw for the grounding conductor. I would however fail you if you wrapped it around the screw the wrong way! ( It has happened more times than I can recall.) The wire has to wrap around the screw clockwise so that the wire tightens up. (Righty tighty, lefty loosey) I think that is how it is spelled!? [Linked Image]
#87969 05/13/04 05:34 PM
After reading this topic and another like it it seems that the local inspector could like using the 10-32 clamp screw or he may not. No one posted and code saying you can't so it will be up to the town your working in I guess.
I also would like to point out not one old work box in my truck has any indication of which hole the ground wire should be installed under.
My opinion is I use the extra 10-32 they give you with the box and toss the extra clamp. I like it and it works.
#87970 05/13/04 05:36 PM
While we are talking about this extra 10-32, why in the heck is the screw on deep old works a hardened screw? It's not on the reg depth ones and is very tough on my cutters
#87971 05/14/04 05:42 AM
Z
Joey D,- I have no idea why the box screws are hardened, they are a pain.
Try using a 32 tooth blade in your hacksaw, works for me!
#87972 05/15/04 10:46 AM
Joe, with all due respect you are taking this one way out there. Sunday I am taking a grounding and bonding course. I will bring this up as the first question. [Linked Image] I wonder how long it will be batted around!
#87973 05/15/04 12:39 PM
Why do you routinely remove unused clamps?
Don
#87974 05/15/04 12:46 PM
It gives me extra space to tuck the wires and I guess that is how I was taught.
Don
#87975 05/16/04 11:53 AM
JG Offline
I would like to ask a question on this, what type of lock nut is holding the clamp. If I had jurisdition and the contractor continued the practice, [and I see no problem in the code with this] couldn't you request a bonding bushing on the clamp? It's the only way to know you have a true bond.
