0 members (), 150 guests, and 21 robots.
That's why the boxes have holes in the side.
P. S. Seriously, would that wire wrapped like that ever have been code compliant?
[This message has been edited by ThinkGood (edited 11-26-2003).]
Workgear for Electricians
"314.23(B)(1) Nails and Screws. Nails and screws, where used as a fastening means, shall be attached by using brackets on the outside of the enclosure, or they shall pass through the interior within 6 mm (1/4 in.) of the back or ends of the enclosure."
I'm going to take credit for the picture above. It is a common 60's vintage wiring method here in the SF Bay Area. Joe Tedesco calls it "Boston Backwrap" so you can see it shows up all over the country.
Another odd grounding method I've run into is splicing equipment grounds on the outside of the electrical box. This was a requirement from the building official in Alameda California. Apparently, a great many electricians received their trainin in Alameda and this practice shows up to this day.
Outer Limits Grounding
[Linked Image from codecheck.com]
Check out the device. I sure don't see these on a regular basis.
125/250-15/20 make-your-own-but-don't-wanna-ground...S
Yes, I saw the ungrounded double 'T' receptacle and thought - why did they bother?
BTW, how long ago were these duplex configurations banned?
