0 members (), 164 guests, and 15 robots.
#82671 12/07/02 10:13 PM
Definately different as Bjarney points out in industrial. The specs, submitals, inspector,architech, clerk of works and the electrical engineer.
Workgear for Electricians
#82672 12/07/02 11:20 PM
Check section 300-15(a)1999 NEC where it says that "Where the wirinng method is...
nonmetallic sheathed cable, or other cables, a box or conduit body complying with article 370 shall be installed at each conductor splice point..."
Harold
#82673 12/08/02 12:57 AM
BJarney,
I'll grab at another nit to be picked.
Awhile back, the cubic inch space in the luminaire canopy was excluded, when doing wire count / box capacity checks. As a result, even the 4" pancake no longer has the volume needed to run a 14 NM into. Clamp + ground + hot + neutral = 8 cubes.
CT,
Your suggestion of box is an excellent solution.
Al
[This message has been edited by ElectricAL (edited 12-07-2002).]
Al Hildenbrand
#82674 12/08/02 02:31 AM
BJarney,
Sorry if I sounded argumentative. I didn't mean to. [Linked Image] I just wanted to be thorough and was musing whether a box recessed in the wall is actually outside the house.
#82675 12/12/02 12:01 AM
Thanks Guys!!!!!!!!
I called the inspector's office at 8:15 am and by 9am he had been to my house and the builder had called me to admit they were wrong.
Have a Happy Holiday Season!!
