0 members (), 246 guests, and 10 robots.
#80490 04/21/02 10:56 PM
V
Mopping up some volunteer work.. Used to help my father a lot, (journeyman electrician, and have taken a few courses myself, but haven't seen enough to know the best fix for this one...)
Q: A volunteer crew decides to add 3/8" drywall over an existing wall. (actually throughout the entire house...) now, as you can imagine, the boxes are no longer flush with the wall, but recessed... Someone told me that they would shim the devices out with washers, but i can hardly believe this meets code..
I seem to recall some sort of box extension is available for this, but havent been able to find it. (perhaps no longer allowed by code?)
(also should mention I am at least 50 miles from the closest building supply center and probably 150 miles from the closest electrical distributor....)
what to do??
Workgear for Electricians
#80491 04/22/02 06:46 AM
Start driving. These boxes should be witihin 1/4" of the finished surface.An extender will do the trick. Check out tis link. www.aifittings.com/m_9.htm
#80492 04/22/02 07:25 AM
V
Thanks, knew they existed, but every search for box extentions lead to nowhere on the web... now to convince the local hardware store to order them for me... [Linked Image]
#80493 04/22/02 04:31 PM
VM--
Have you tried contacting Arlington directly? (They might UPS you a package of 25 just for asking...for a volunteer project.)
