530
22
Posts: 2,236 Likes: 1
Bill, you get the credit for the fact that I now use #14 for lighting loads...
Heck, someday I might even use #14 for convenience receptacles (but a 15A breaker makes them "less convenient" in my opinion, subject to callbacks when the circuit is "overloaded"...)
Tom, I like the SPDT switch idea (not really a 3-way in that usage) for the nite-lite.
I had a call back once where I had to install a stacked (duplex) switch at a $7 loss because the Owner didn't want the 7W bulb burning 24-7.
Wish I had thought of the SPDT thing then...
The last few I've installed didn't have the nite-lites...(?!?)
Yes, Bill, I'm serious. Kitchens too. It's Sunday, but I'll try to find the Code reference and post it ASAP.
They still sell (& I'd presume install) them here. I have one with a fluor retrofit lamp in it. (please don't call the authorities on me). I ran dedicated circuit to a metal switchbox, and used 12-4/g type M/C cable up to the unit.
[This message has been edited by electure (edited 10-21-2001).]
electure, Nutone makes a fan/fluorescent light combo. It complies with the Title 24 requirement of fluorescent lighting in bathrooms and kitchens here in CA.
Once again, my foot is in my mouth!! I received an e-mail (good) from "Ross" with this CA Title 24 excerpt: "Each room containing a shower or bathtub shall have at least one luminaire with lamp(s) with an efficacy of 40 lumens per watt or greater. If there is more than 1 luminaire in the room, the high efficacy luminaire shall be switched at an entrance to the room." Ross's interpretation of this, (as well as mine), is that there must be @ least 1 fluorescent fixture in a bathroom, and doesn't prohibit the use of incandescent lights in addition to the fluorescent. Kitchens are a different deal altogether. Thanks, Ross. (me & my big mouth) ![[Linked Image]](https://www.electrical-contractor.net/ubb/biggrin.gif) Welcome to Bill in LA! Bill, is this unit also available with a heater? (my Nutone catalog is a dinosaur) [This message has been edited by electure (edited 10-23-2001).]
Posts: 4,161 Likes: 5
That makes more sense now. I couldn't see how Californian ladies could get their makup on straight with just a dinky fluorescent light over the vanity. (Unless the hype is all true and they don't need it? ![[Linked Image]](https://www.electrical-contractor.net/ubb/smile.gif) ) It's probably not a very flattering light to skin-tones either, is it? Bill
To All: I cant believe what I just read on a heat/vent/light/night light combo, at least in my area and in the code two cables run to this unit would be gigged immediately. Via 300-3(b) all conductors of the same circcuit and where used, the neutral and all wquipment grounding conductors shall be contained with in the same raceway, cabletray,trench, cable or cord.,,, 12-4 or 12-5 MC works nicely on these units.
bordew, I had read the same thing. That was part of my reason for asking the question. I've never seen them wired with one cable though. ![[Linked Image]](https://www.electrical-contractor.net/ubb/smile.gif) Bill
Bordew, If the heater is on a different circuit from the light&fan, why could you not run 2 cables?
Yeah, I thought the heater would *have* to be dedicated, considering its load (1500W)... It is continuous, unless there's a timer, I suppose...(?) ![[Linked Image]](https://www.electrical-contractor.net/ubb/confused.gif)
I've got a dedicated 20amp circuit to mine, with a 15 min. spring-wound timer for the heater. If a guy has 2 circuits to the unit, then there shouldn't be a problem with 2 cables, should there? BTW, Nobody makes 12-5 MC cable that I know of. AFC makes "home run cable" that comes in 6 and 8 conductor configurations, but generally MC is available in 2, 3, or 4 conductor.
