0 members (), 274 guests, and 11 robots.
#78175 08/27/01 09:38 PM
I had heard the statement about the lack of copper during WW2. I have also heard that this requirement was in the code way before the Big One. I will look into my old code books tomorrow to see if I can verify this.
As for the fact that there have been deaths caused by this, I would say - no way -.
If there were deaths that have been caused by this, do you really think it would have taken 50+ years to get the code changed? I have heard of long discussions by the code making panels, but 50 years?
There has been only one death locally that was involving a dryer. The teenage was laying on top of the dryer, and reaching down behind it to unplug the unit. He worked the plug out some, then grasped the plug by wrapping his fingers around the blades, which were still energized. Current thru him to the unit. This would have happened whether the unit was wired via 4-wires or 3-wires.
I honestly believe most deaths have happend because of damaged unit, or by mis-use, like this kid, and not because the unit had only 3-wires.
I like the rule for not having the neutral used as a ground. It is pretty hard telling an apprentice that you do not tie neutrals and grounds together anywhere in a home, but then telling him/her that it is ok to do it on a dryer/range. The new rule makes sense.
Rick Miell
Workgear for Electricians
#78176 08/27/01 10:33 PM
We are all missing the obvious solution. 240 Volt motors and the whole thing goes away.
Less current draw, also.
#78177 08/29/01 09:00 PM
Anonymous
Unregistered
And 240 volt timer (if not solid state electronics)? And 240 V interior light bulb?
#78178 08/29/01 09:10 PM
Why not? Double pole controls? The electronics is stepped down, anyway.
It still seems better than grounding the neutral at the frame for all those years.
#78179 08/30/01 07:39 AM
I've never owned, or don't think I've ever seen, a dryer with a light bulb inside. Who makes those?
I think Redsy's got a great idea here.
[This message has been edited by electure (edited 08-30-2001).]
#78180 08/30/01 11:35 AM
I just bought a kenmore dryer and it does have a light inside. very nice since I have yet to install the lights in the laundry room!
#78181 08/30/01 05:29 PM
Anonymous
Unregistered
I think half the dryers have a light bulb in them. This is not a recent innovation. Lights have been in dryers all my life.
#78182 08/30/01 05:45 PM
I think I 've seen a few with bulbs (but none in my house... my dryer is as old as me!)
But, yeah... Great idea... solves a whole host of problems...
Cheaper cable, cheaper plug, cheaper recept., more "fool-proof"... What's not to like?
-Virgil
5 Star Inspections
Member IAEI
#78183 08/30/01 06:08 PM
Anonymous
Unregistered
A. They would be lot more expensive to design an build.
#78184 08/30/01 07:23 PM
Thanks, the wife is demanding a new dryer. The old Kenmore with new parts just won't do again this time ("See hon, works just like new"). A new Kenmore with a light inside it'll be! [Linked Image]
