Minimum 12-2-G in extension cords for 3 to 12'? If proper spacing is kept for Receptacles, extension cords are unnecessary.
But I like the idea.
Integral OPD on each device? As long as the circuit is protected as per Code, this would be unnecessary.
20 A plugs on blow dryers? Great Idea! for those above 1440W...
Different base for light bulbs above 60 W? Mogul base for 75W and up? Or similar? Not a bad idea either.
Metal conduit or armor everywhere above ground? Or sched. 80 PVC (assuming outdoors)
U prongs up? Don't get me started again...
![[Linked Image]](https://www.electrical-contractor.net/ubb/biggrin.gif)
Thanks for all the replies! I
still can't get AFCIs through any of the suppliers in this area , though. Tom, have you had any luck?
[This message has been edited by sparky66wv (edited 05-04-2001).]
