1 members (gfretwell), 513 guests, and 9 robots.
#74030 01/12/07 05:38 PM
T-5s are good, they are also still fairly expensive to buy lamps and ballasts for.
I also see a much higher failure rate with T-5s.
I am sure the technology will improve and the price will drop,
With that in mind I would light a typical garage with T-8's they work well, are inexpensive and durable.
JMO, Bob
#74031 01/12/07 05:41 PM
but i have used the HO fixtures many times with out any problem. and they will provide good amount of light.
I agree they did work fine, I have installed many. [Linked Image] My own garage and part of my basement have 8' HOs.
But you will see all T-12 size lamps being phased out. I am not sure the reasons but they are going away.
#74032 01/12/07 07:41 PM
Not sure of the reason??? Think energy efficiency and government environmental mandates.
#74033 01/12/07 10:44 PM
Although this is not about the task lighting you are talking about here, i might suggest another incandecent light on a motion/occupancy sensor. That way you are never wandering around out there in the dark. It helps when your arms are full.
[This message has been edited by gfretwell (edited 01-12-2007).]
#74034 01/13/07 10:25 PM
Do you guys have an fixture recommendations for T-8 installations? I am particularly interested surface mount fixtures that are suitable for frequent switching, eg. with 'programmed start' ballasts.
-Jon
#74035 01/14/07 01:25 AM
Lithonia offers programmed start ballasts as an option across their full line of T-8 fixtures. Not sure how much extra they cost, or how many you have to buy, but they will supply them.
I suspect that other manufacturers are the same. The big question will be the term to payback of the increase in initial cost.
#74036 01/14/07 04:03 PM
K
kencr Offline OP
Rather then going with the 96" T-8 HO fixtures. I ordered the 96" channels with four T-5 54 watt HO lamps.
I will be needing sunglasses in the garage if I have them all on at once.
Thanks for you your comments
#74037 01/14/07 07:27 PM
I see many of you have stated that T8's light in very cold weather and to discard HO T96's.
I put T8 in my personal garage ands when it gets in to the 40's F One of them wont start till it has been on for a while. Colder it gets the worse it is.
#74038 01/14/07 07:56 PM
Well that is not 'normal' you may have a weak ballast.
In general the T-8s will light right away but will take a few minutes to come to full intensity.
Same as any of the CFLs that have become so popular.
When you replace a typical 2 lamp 8' HO with a typical 4 lamp 8' T-8 you will have greater light output and the power consumption is less than 1/2 of the HOs.
A typical F96-T12/HO 2 lamp 120 ballast uses 237 watts and has a min start temp of -20F
2 lamp 8'Ballast
A typical F32-T8 4 lamp 120 ballast uses 112 watts and has a min start temp of 0 F
4 lamp 4' ballast
#74039 01/14/07 09:10 PM
K
kencr Offline OP
I have changed some new old stock 2 lamp T-8 ballasts that were in vapor tite fixtures. That were not 0 degree start. They were 50 degree. Since we were putting them in walk-in coolers.. the 50 degree ballasts had to go.
