0 members (), 150 guests, and 21 robots.
#73080 12/17/06 09:32 PM
The only time I hated working out of a pick up was when it was raining. The van offers shelter while your in there getting stock of putting it away.
I think a canteen truck with the 3 doors that flip up and offer some coverage from the rain would make a great sparky truck.
#73081 12/17/06 09:52 PM
The wall that separates the driver from the rear of my van has a door in it. Can access the back of the van without getting rained or snowed on [Linked Image] http://www.adriansteel.com/vbaseplus.htm
Some pretty sweet shelving too!
#73082 12/17/06 11:03 PM
How long do you keep your trucks ? Take it from a long time Chevey driver about 85,000 miles the in tank fuel pump is going to be replaced and in a pickup the best way to change a fuel pump is to slide the bed back.My 96 had 3 replacement fuel pumps.The factory pump lasted 87,000 and the other 3 were put on between 87,000 and 109,000.Knowing that and after spending hours unloading the pickup I would think looooooooong and haaaaaaaard about working out of a pickup/toper setup
#73083 12/17/06 11:28 PM
Maybe you should cut an access panel for easy fuel pump changeouts!
We used to cut a hole in the firewall to get to those freezeplugs on the back of the head, then just patch it up.
