0 members (), 1,288 guests, and 21 robots.
#69828 09/20/06 10:45 AM
K
Kenbo Offline OP
Here is a small puzzle I was asked about.
12 resistors of 1 ohm each, are conected to form a cube (my drawing skills are awfull)
At two corners diaginaly opposite each other are marked A and B, (so you have to pass through three resistors to get from A to B)
What is the total resistance of this circuit?
der Großvater
#69829 09/20/06 11:41 AM
0.5 ohms?
#69830 09/20/06 12:50 PM
Bob Offline
"At two corners diaginaly opposite each other are marked A and B, (so you have to pass through three resistors to get from A to B)"
Maybe
I am reading more into this than needed. If each side has 3 resistors you would have 12
installed in the cube. You would go thru 6 resistors to get from A to B. Are you requiring the circuit to be constructed so that you must go thru 3 resistors from A to B?
#69831 09/20/06 01:06 PM
K
Kenbo Offline OP
Bob
Imagine a wire model of a cube It would need 12 lenths of wire to construct. But each is a 1 ohm resistor. What is the restance at the two furthest away corners of the cube?
I will try to post a pict
Alan 0.5 ohm ? how did you get that (not correct though)
der Großvater
#69832 09/20/06 01:37 PM
The result is 5/6 ohms
The circuit can be re-drawn as three 1 ohm resistors in parallel(=1/3 ohm), in series with 6 1 ohm resistors in parallel (=1/6 ohms), and then another 3 1 ohm resistors in parallel (=1/3 ohms).
The reason this can be done will become apparent once you re-draw the circuit, and is based on the fact that all the resistors are identical.
#69833 09/20/06 01:40 PM
Bob Offline
I understand that. The cube has 4 sides. That would take 3 resistors in each side to use 12. If so the equivalent R = 3.
#69834 09/20/06 01:59 PM
I concur with MaxH, it's 5/6 or .75 ohm
#69835 09/20/06 02:51 PM
When I sat my Trade Cert as an Electrician in 1994, this question came up.
With 3 hours for the whole exam, it was certainly a stumbling block.
I think it is the idea of a cube that throws a lot of people off.
#69836 09/20/06 03:31 PM
5 divided by 6 isn't .75 its .83
#69837 09/20/06 03:40 PM
Kenbo; just a lucky guess!
Actually, I worked it out while roofing a dormer today and the sun must have addled my brains, ie. 1/3 + 1/3 = 1/2 . DOH!
Still, only 1/6 of an ohm out!!! [Linked Image]
This is how I figured it:
Let each corner be designated a letter,
A,B,C,D,E,F,G,H
Each resistor can then be identified by a pair of letters ie. 'AD'
From point A we get, [from my layout]
AD+AH+AE, in parallel, = 1/3 ohm
Call this the first leg.
PLUS:
HC+CB =2ohm parallel 2 ways = 1 ohm
HG+GB =2ohm
EF+FB =2ohm parallel 2 ways = 1 ohm
EG+GB =2ohm
DC+CB =2ohm parallel 2 ways = 1 ohm
DF+FB =2ohm
But these 3 routes are also in parallel to complete the 2nd leg;
Total for second leg = 1/3 ohm
1/3 + 1/3 = 2/3 ohm total resistance
Alan, Class Dunce of 1948!
ps. I just spotted I got 15 resistors, [some used twice], so I give in!
[This message has been edited by Alan Belson (edited 09-20-2006).]
