0 members (), 575 guests, and 24 robots.
#69476 09/10/06 11:35 AM
aldav53 Offline OP
How does a load controller on a home work? We have the on-peak/off-peak hrs set up here on our meter.
#69477 09/10/06 12:15 PM
Typically it is simply a time clock that shuts off power to certain appliances during peak usage hours.
#69478 09/10/06 01:00 PM
The FPL controllers are addressible so they can turn off the selected loads whenever they like. They do try to do a rolling blackout of the loads so you are not without A/C or hot water for long (typically 30 minutes or less at a time)
My mom had it and she says she never really had a problem.
#69479 09/11/06 09:35 PM
I have heard of it a number of ways.
One is with a cut rate off peak meter, which is activated through a pilot fed contactor, another just disables the loads on the normal metered service in peak times.
Recently, Toronto and some other cities have institused remote A/C disconnects, which turn off yours and many others A/C on radio command.
I have seen a load splitter, which allows you to selectivley feed a large heating load or other intermittent loads. It would give preference to the other loads, and disconnect the heater to let the other loads use the same power.
#69480 09/12/06 08:54 AM
Concerning the FPL load controllers, I can say the system is completely transparent.
I have had it on my water heater and A/C for the last 15 years or so and have never noticed it's operation. I do notice the discount they give me on my power bill though.
{Edited, cuz I kant spel}
[This message has been edited by IanR (edited 09-12-2006).]
