0 members (), 1,002 guests, and 12 robots.
#64945 04/22/06 02:16 PM
another way to remove those sharpie marks is to write over the mark with a sharpie then quickly wipe it off. The new ink softens the old ink on metal, plastic etc.
#64946 04/22/06 03:28 PM
tkb Offline
Some of my pet peeves are,
  • Sharpie marks on the bends.
  • Couplings that don't line up on a rack.
  • Not trying to match an existing run.
  • Pipes that cross when they didn't need to.
  • Boxes that are hard to reach. If it’s hard to reach when installing, how do you expect to pull the wire.
  • The strut straps that have a setscrew into the pipe.
  • Piping with pre fab bends and a lot of couplings. I prefer bending everything 2” and under, I understand fittings for 2-1/2 and larger. The big bender is time consuming for a couple of bends.
  • Using cheap die cast fittings. I like steel but use whatever the budget calls for.
  • The screws that all the manufactures are using now. The combo, straight, Phillips, #3 square drive. None work that great, never have the right tool. 10 in 1 doesn’t work very good, the tool is usually too small.
  • Having to improvise on fittings or a bends when planning would have helped.
  • Short pieces in a run with couplings close together. I will cut the longer piece to space the couplings out and make it look better.
  • Open and closed bends, also wows and doglegs. I just started using a no dog level and I like it and highly recommend it especially over 1”. I guess you can teach an old dog new tricks.
  • Questioning my judgment. I will listen to ideas though and sometimes use them.
  • Calling “Conduit” ; “Pipe”. I am an offender I know. Some people only call RGS conduit.
I like to put the setscrews on the top of the pipe. I looks better from the floor and it doesn't deform the bottom of the pipe end in the coupling. When the screws are on the bottom and the screws are not tightened the same you could get a lip inside the coupling on the bottom where the wire lays. On the top who cares.
I also watch and anticipate the pulling force at the 90s and support them in addition to the straight runs.
How do you know when the EMT connector set screws are tight enough? The Value Engineered materials that we use some times seems very low budget. You can tighten these screws and the coupling or connector starts deforming and doesn’t seem to be tight enough. It feels like the connector will split. This is for die cast mostly.
Does anyone still do concentric bending? It looks sweet on a rack.
For the best looking conduit runs that are easier to pull remember the 6 P's.
Proper Planning Prevents Piss Poor Performance
Sorry if the language is not appropriate.
My favorite is PVC coated. When install correctly with the correct tooling and fittings it looks awesome.
If you can run rigid and make it look good without extra couplings or erickson couplings, you can run anything.
I know that most of these thing that we are discussing are only noticed by other electricians and most people would never look twice.
You can always spot an electrician in a nice building because he will always look up after he enters the building to check out the electrical work. Myself included. Tell me that you don’t do this and I would say you are lying. [Linked Image]
Tim
30 years of conduit installation. EMT, Rigid, PVC, Aluminum, PVC coated Steel, PVC coated Aluminum, Fiberglass.
[This message has been edited by tkb (edited 04-22-2006).]
#64947 04/22/06 09:39 PM
I forgot one of my favorite peeves. Its looking at an lb that is flying out in the air on a conduit run, not really getting used to go around any corner or anything, just sitting out there all unsupported. LB's used at services and gutters are not included in the above, those are ok by me.
#64948 04/23/06 07:09 PM
Tim,
Where can I find the no dog level. Can't seem to find the thing anywere.
Phil
#64949 04/24/06 03:03 PM
tkb Offline
There are many variations of the No Dog level around.
Right now I have the Maxis Speed Set http://www.maxistools.com/product/speedset/
I don't really like it that much because the bubble is longer than the lines in the level. It is probably because air leaked into the vial.
No Dog is at http://www.no-dog.com/ I know that iwire has purchased these so maybe he can give his comments on this brand.
Greenlee makes one also. You can get it at ToolUp http://www.toolup.com/productInfo.asp?pid={954BAB99-C357-4266-AC95-4F7277BEED3F}
I think I will be getting a new one and I think it will be the Greenlee.
When you use one correctly, it does help with your bends.
I don’t think it matters if the bender is level, just that it is in the same position for both bends. The level makes sure that you rotated the pipe 180 degrees.
#64950 04/24/06 04:27 PM
I have used the "no dog" brand for over 15 years....still using the same one, and it gets abused - bottom of the toolbox, falls out of my pocket on a lift, etc. Works fine still.
I am considering "upgrading" to the GreenLee model($36). The GreenLee model costs about 3x what the original no-dog costs($12) and is about $5 higher than the "no-dog" brand tool with 5 vials(no thumb screw~$30). The GreenLee model has 4 vials and a thumb screw .
~~ CELTIC ~~
...-= NJ =-...
#64951 04/24/06 08:05 PM
e57 Offline
Kdal, looks like you covered just about all I would have to offer, spare a few.
"Proper Planning Prevents Piss Poor Performance"
Oh Yeah!
I usually start a job (large job that is) by doing some thourough planning. I get myself a new box of mechanical pencils, and a zerox copy of of the RCP's for each floor. ~$20 at a office supply store darn well spent! (Lot cheaper than plan printing service) Large format copies of a few pages of the plans, just to pencil in conduit runs, cable runs too. Just draw them right in.... And plan for the future. (And extra conduit, or in the very least, room for one.)
Line Diagrams
Right back on planning.... Try to hang more conduit that you have to bend. That goes with out saying, but have seen people layout runs where it seems every piece is manipulated in some way. The fewer bends you make, the easier the pull, and looks better too. Sometimes it is much more efficient to remove an obstical, than go around it. I recently went to a job to see a guy making 20 saddle bends past a single piece of existing 1/2" at different points on the cieling. (I got ticked off.) It was much more efficient to just remove it and incorporate it into the work, and would have looked better too.
As for the 'No-dog' - great tool, not totally nessesary... And I can rarely find mine. I learned other ways to get around that before I heard of that tool, and seeing that I usually have no idea where it is, I stick to this standard method.
Bender notches
Make an issue of KO seals by issuing them only when needed with a snear and lecture. If there is a box of them laying around, people are less descriminate about finding uses for them, and not thinking before they knock out boxes.
And this one, is just my opinion... Sometimes pipe is a 2 man job. IMO it goes a lot quicker with one on couplings and doing the bends, and another on straps and boxes. (So long as more work than talk...) This way set coupling get tight without someone having to hop around from the strap, and back. Or, one guy measuring and installing, and the other bending and cutting. When doing racks I usually bend on the floor from called out measurements and just pass them up.
For 1/2" I have a 1/2 sized bender handle. A full bender handle is not nessesary for leverage in that size. Which can be very handy in some situations. I carry it in a hammer loop, bend in the air with it resting on my thiegh/knee, against the wall, or on the floor. It is just easier to handle, without the long handle...
#64952 04/24/06 10:29 PM
I've got one like that with an 1-1/2" offset bent in the handle.
I use it for "special" bends. You can bend 180° in about 13", and the handle never gets in the way.
#64953 04/25/06 08:22 AM
Great topic!!
Has anyone used the MAXIS Marksmen tool to layout KO's in boxes? It looks like it would be useful once you get used to it.
See link below: http://www.maxistools.com/product/marksman/
#64954 04/25/06 06:18 PM
F
I bought the Maxis Marksman about a year ago. I love it!! I bought it when I had a job that involved punching out 6 tubs. It made the whole layout process really quick and fun. I was sorry when I ran out of tubs on that job. I'm about to really put it to use again in the next week or so. I have 10 tubs to lay out and punch.
