1 members (gfretwell), 308 guests, and 8 robots.
I did a bit of looking around. The Leviton 8299 is a combination GFCI with a single receptacle and a single pole switch. The only problem with it is that the switch is rated for 8.3A. Also the receptacle is a 15A receptacle, so you couldn't use it on a 20A circuit.
Pass and Seymour list 15A GFCI receptacles with 15A switches, and 20A GFCI receptacles with a night light in place of one of the receptacle outlets.
http://www.passandseymour.com/pdf/E.pdf
I'm sure that other manufacturers make devices where one 'outlet' of the GFCI is replaced by something interesting.
-Jon
e57 Offline OP
Now Scott thats not very nice... [Linked Image] We have already had the conversation about why its a bad idea, and thay have already deleted a lot of equipment.
Jon, night-lights sound interesting, as they would all be behind equipment, like back lighting at night. [Linked Image] I like the idea of a glowing coffee machine.
Lostazhell, when was that style of GFCI receptacles used, I have only ever seen one of them in real life - at an airport. I would like to get my hands on one to add to my collection!
Anyway...
Single recepts will only be required for eqipment fastened in place.
Required by who?
Not the NEC. [Linked Image]
