1,092
11
Well, I guess they still do make 'em....
Posts: 3,672 Likes: 5
Administrator Member
posted for skingusmc: When I started looking around this house I found none of the previous homeowner's splices used anything but the twist and tape method. He wrapped stranded wire around the solid and folded them over, pinching the stranded. It looked very ugly but I have to admit I didn't find one that had any signs of heating, even in the 1440w bathroom heaters. gfretwell, Did it look something like this... - Steve (skingusmc) [This message has been edited by Webmaster (edited 03-23-2006).]
Posts: 2,520 Likes: 2
In Austria I've seen another type of splice. Take a rather thin screw (think a cover plate screw) and a weird nut with three wings sticking up if you lay it flat on a table. The wires are bent around the screw and the nut is tightened, the wings keeping the wire from silding out. Then everything is taped. I stumbled over those at a friend's place (supposedly 1961, but very conservative wiring in most regards) and first thought of replacing them. in the end I just unwrapped each and every one, tightened the screws and retaped. Probably lasts longer than anything else. Don't care for making up such a connection though...
I'm still wondering why theres a keyless in the foyer. Unless its a brushed nickel keyless... then say no more.
Shake n Bake
Posts: 10,056 Likes: 40
Steve, yup that's the one. Where did you find that? I am curious who used that method of splicing.
gfretwell -
"Steve, yup that's the one. Where did you find that? I am curious who used that method of splicing."
I'll send you a copy of what I have via e-mail.
I found it while looking for a "Western Union" splice.
Steve
Thanks Steve
