Gidday there Dave,
If I need a Masonry drill unit, I swear by the Hilti.
I own 2 of these units, a TE-15 and a TE-25.
The TE-15 has 2 inter-changable chucks and can also be taken off of "hammer" to function as a standard Drill motor.
It has a 13mm 3-jaw chuck and the SDS chuck as 2 seperate units.
The TE-25 has just the SDS chuck.
You can use either of these units with a Core-bit, I've up to 100mm diameter in them and they really work well, really handy for boring holes in brick/concrete walls for A/C pipes/wires, as I used to do.
If you can burn out one of these drill units, you need to find another trade.
{Message edited because of a couple of typo's}
[This message has been edited by Trumpy (edited 12-08-2005).]
