310.11 Marking in the 2002 code says ____________________________________________ (A) Required information. All Conductors and cables shall be marked to indicate the following information..... (1) The Maximum rated Voltage (2) The proper type Letter or Letters for the type of wire or cable as specified elseware in this Code (3) The manufacturers name, trademark, or other distinctive marking by which the organization responsible for the product can be readily identified. (4) The AWG size or Circular Mil area (5) Cable Assemblies where the Neutral conductor is smaller than the Ungrounded conductors shall be so marked
(B) Method of Marking (1) Surface Marking The following conductors and cables shall be durably marked on the surface. The AWG size or circular mill area shall be repeated at intervals not exceeding 24" ....... (1) Single- and Multiconductor rubber- and thermoplastic- insulated wire and cable (2) ....... ____________________________________________
I've pulled 500 mcm THHN off of reels in sub-zero temperatures and had had the outer jacket blow off the conductors, the entire length. I thought it was wrong and said something about it, But it still wound up getting installed. Don't crucify me for doing it because it ended up in an underground mine. but we try to do things down there just like we do things on any other job or better. On a seperate occasion i've seen all of the insulation blow off of wire pulling it off the reel during cold weather. It was impressive to see and hear! A loud bang and then Bare copper. Ended up calling the manufacturer and they said THHN/THWN is not supposed to be installed While the temperature is below 20 F
Justin
It's Not The Fall That Kills You... It's That Sudden Stop At The End
Justin, Don't think for a second that you would be crucified here, for posting that. My God, if that is what it takes, we'd all be leaving here!.
