0 members (), 149 guests, and 34 robots.
#53529 06/28/05 08:47 PM
If this a commercial location, there shouldn't be any 15-amp circuits. If residential, this sounds like a kitchen, these are kitchen appliances, and should be on 20-amp circuits anyway.
I'd specify at least two new circuits: one for the copier aznd one for the appliances. The computer should be separated from these appliances anyway, and a 15-amp circuit is plenty for it.
YMMV
Larry Fine
Fine Electric Co.
fineelectricco.com
#53530 06/28/05 10:58 PM
BigB Offline OP
Thanks for all the great replies The building is an old house that is being used as an office for ajoining apartment units. What I have decided to do is run two circuits, one for the coffee maker and one for the copier. I had ruled out the coffee maker because they said it happens when it is not being used, then I remembered these coffee makers hold a quantity of hot water which they re-heat periodically. Since I can't spend a lot of investigative time there and the request was to make the circuit stop tripping I think the two circuits is the way to go.
#53531 06/29/05 01:28 AM
I would probably run 3 circuits, one for the copier, one for the fridge, and one for the coffee maker.. leaving the 15 amp circuit for general utility use.
