1 members (Scott35), 355 guests, and 38 robots.
#5352 11/16/01 10:11 AM
JBD Offline
NQOD is a brand name of Square D, it is not listed as a tradmark. It is a lighting and appliance branch circuit panel rated at 240VAC max.
All of Square D's lighting panels (as opposed to loadcenters)are prefixed with an N. In the old days their power panels started with an M.
The QO stands for the type of breaker and really means nothing. QO was simply a new letter designation (older breakers were types MO and XO). However 15 and 20A 1Pole QO breakers feature a "QWICK-OPEN" construction.
The D stands for dual connection bus bars. The panel accepts plug-on and/or bolt-on breakers. The older NQO panel was for plug-on only and the NQOB was bolt-on only.
#5353 11/16/01 07:59 PM
Thank you, JBD. I had some hesitation with my own estimation of the designation but will submit yours and have confidence that it sufficiently explains it.
