0 members (), 151 guests, and 9 robots.
#52635 05/31/05 11:09 PM
I have found the Sq D QO200TR to be a useful disconnect. It is rather compact, rated for 60 amps, and you can replace the disconnect switch inside with a QO breaker if you wish. Cost near $12, also avail in plastic. Originally intended for air conditioner use.
#52636 05/31/05 11:12 PM
e57 Offline
I guess that is another place it could fall under too, as it is an appliance as well.
