1,056
Local3Jr, What 3 IBEW locals make the most money per hour? are you going to give us an A,B,C,D, choice? ![[Linked Image]](https://www.electrical-contractor.net/ubb/wink.gif) Welcome to the forum, but Union or Nonunion affiliation is a blind issue here. Roger
Local3Jr,
I agree with Roger, leave that out of this....
{Sentence removed by Webmaster} Dnkldorf: Let's not stir anything here.
[This message has been edited by Webmaster (edited 01-09-2005).]
Dnk,
Someone is not a word. I think you meant to say some one.
Posts: 4,165 Likes: 6
Local3Jr, In case you don't know, We're a mixed group here, we don't talk about affiliations. We focus on the Codes and doing the job better and safer. With that said, Welcome to ECN. ![[Linked Image]](https://www.electrical-contractor.net/ubb/smile.gif) Bill
State NEC ?
the national electrical code 344.26 not more then 360 between pull points.
Yep, Box off-sets count too!
You have no idea how many times I say that to people that have been at this for years.
And I'll take a stap at Local3jr's Q?
Chicago, SF, and NYC. If not LA.
Posts: 2,236 Likes: 1
Yes, let's say three-phase...
(Oops-forgot that little important issue)
Hmmm...
I get 161 #8's in a 4" EMT non-cont rated will net me 17.5A and a 20A Breaker.
Correct?
711- 14 AWG type Z conductors in a 4 in EMT conduit, as per Table C1 - page 646 NEC 2002. Using a 6 amp fuse as per 240.6(A) - This is feeding many motors ![[Linked Image]](https://www.electrical-contractor.net/ubb/smile.gif) . Pierre [This message has been edited by PCBelarge (edited 01-09-2005).]
Pierre Belarge
In a 2 story dwelling do you need smokes down stairs even if there is no hallway?
In a basement you have 2 exits does code require lights to be on 3, ways
If you have an ISO ground bus in a sub panel can you take this wire and bond it directly to the cold water pipe?
When wiring an Elevator when and why do you a Shunt Trip Breaker?
3 phase 480v A/C unit has a 600V disconnect slow blow fuses does the breaker still need to be HVAC rated?
How many breakers are allowed in an out building sub panel before you need a main disconnect on that sub panel.
The foreman tells you; above the ceiling is a conditioned space. Does this mean you have to use compression fittings? What about phone and data cable, fire, class 2 wires? Does it need to be in EMT?
Dnkldorf: makes no difference
