Bucketman,
If you're talking about the text image rather than the pictures, it came from
"Soares Book of Grounding", published by the International Association of Electrical Inspectors, not the NFPA (and incidentally available through ECN's bookstore).
It's considered to be the most authoritative book available on grounding and bonding.
Well, since I'm here anyway, here's what happens when the fitting is tightened (maybe with a wrench?) and the locknut doesn't pierce the paint. Just a 20A 120V circuit that had a ground fault. These were both tight.
1. This KO was slightly oversize, looked like someone went a notch too far with a step drill
2. Here's the conn on the other side of the box. This KO was the proper size.
3. Inside shot of the conn in #2
[This message has been edited by electure (edited 11-22-2004).]
