0 members (), 1,298 guests, and 12 robots.
Page 4 of 4 1 2 3 4
e57 Offline
Joe, or a bare #14! Melts right through with the same method.
Dave55 Offline OP
Thanks guys. I got booted off the job for an hour yesterday, so I went tool shopping and got the Panasonic. All I have to say is...Baby, where have you been all my life! Quick, quiet and much less burr than the reciprosaw...hardly enough of a burr to even mention. I don't care for the way it talks to me though.
Dave
You might be allowed to use a tubing cutter with EMT, but I'll never do it. My dad's a plumbing contractor, so I've cut a lot of copper with a tubing cutter in my day. It not only leaves a burr, but it also bends (tapers) the pipe inward slightly. Obviously no big deal with plumbing, but with EMT, I feel this can catch on the wire. You can remove the burr, but you'd have to flare the pipe end just a bit in order to straighten the pipe to the profile it once was.
For 1/2" and 3/4" EMT, I use my Lenox Hackmaster with a 32TPI blade, and I ream the 1/2" with my Klein needle nose pliers, and the 3/4" with my Kleins. I stick the pliers in the EMT to ream the inside, and use the recess on the backside of the cutter to clean up the outside. Yes, it's a two part process, but geez, I've got too many tools in the bags as it is. With IMC or RMC, I use a Ridgid pipe cutter, but I also use a Ridgid reamer to deburr.
I did have a bad experience with a hacksaw though. I was cutting a piece of 1/2", and I had a 24 or 20 TPI blade in there. The blade bounced along on the EMT, and ended up coming down on the top of my finger right before a full stroke. Well, I stopped quick so it was only a 1/2 stroke at best, but it still opened up the top of my knuckle.
[This message has been edited by royta (edited 09-17-2004).]
Page 4 of 4 1 2 3 4
