0 members (), 357 guests, and 52 robots.
#38620 05/27/04 10:49 PM
I want to tap off an existing welder outlet,that is not used and feed a 20 a 2p breaker that will feed an A/C unit. Is it legal? The breaker will be in a small QO panel.
#38621 05/28/04 06:34 AM
If the conductors are sized properly and you use some type of switch/disco that will allow only one to be on at the same time, it is OK.
AllClear
AllClear
Belmond Iowa US
dsk 1
555,970 Are you busy
430,807 Re: Forum
400,237 Need opinion
