1 members (Scott35), 179 guests, and 11 robots.
#37643 05/01/04 04:57 PM
Curt...
One reason I pointed out to unplug/disconnect "everything"... I should've noted for both circuits though.... my bad! [Linked Image]
Thanks for pointing that out! [Linked Image]
Now that I'm thinking about it, You could probably just leave the power off & ohm out between the ground & neutral at a recepton the problem circuit with the power off to BOTH circuits in the 14/3 & see if theirs any continuity!....
-Randy
[This message has been edited by Lostazhell (edited 05-01-2004).]
#37644 05/01/04 05:34 PM
Thank you all for the advice.
