0 members (), 184 guests, and 14 robots.
Thanks to all!
The list has changed a bit and with some great suggestions and some new ideas!
Boy Howdy, Scott35.
wa2ise — One distinction for electrical-engineering specialties seems to be that some do work that affects new or modified real estate, and in a lot of cases PE registration is expected, versus those that deal with complex signal analysis or mega-gate logic and are fluent in physics terminology. I am retired from a place that has many of both. I used to hear that one distinction was that the two factions worked on “opposite sides of the decimal point,” but that was not always the case.
I assure you that linear accelerators and supercomputers involved plenty of work on both “sides.” It was not unusual there to find DC power supplies with sets of 100kVA oil-insulated transfomers and rectifier stacks cooled with deionized water, or 18-section motorized Powersats with thousands of feet of 535kcmil 2kV diesel-locomotive and 350kV-coaxial cable.
Too, there was always some weird synthesis of the two sides—where electricians would use time-domain reflectometers and Dewar flasks as “warm for hours” coffee cups, versus instrumentation techs would routinely use 80kV cable test sets and install NEMA size-4 contactors in their equipment racks. [In many cases both valued a working knowlege of the NEC.]
[This message has been edited by Bjarney (edited 04-13-2004).]
LK Offline
Bjarney,
You said it well, may i just add, other then PE's for the construction field, engineers that work in the manufacturing plants, also need to be code wise.
Oh, Joe—could you hang on to the check? Instead, can I have crab cakes next time I stop in Boston?
P.S.: No offense meant, but are drivers in Cambridge still half crazy? My one trip to Massachusetts in ’95 left me breathless.
